Create Thingworx mqtt broker
Hello Team,
I am trying to implement a solution that has 2 branches :
Branch 1 : publish sensor data through simulated devices on node red to Thingworx iot platform using mqtt protocol
Branch 2 : create web application in nodejs that subscriber to these messages using mqtt
The only problem i am facing is that , from my understanding of all the threads on this community, thingworx does not provide any mqtt broker for mqtt connectivity. It only provides an mqtt client like eclipse paho and we need to integrate the mqtt extension with our own mqtt broker: that can be AWS, Azure or Mosquitto and so on.
Kindly confirm and suggest otherwise
Aarushi
zyuan1Answer
We only used Kepware as remote data source, and it cannot be used in MQTT communication.
For MQTT extension, we have Market Place version and a pre-release version, but there are only differences in configuration settings and some possible performance improvements, you still need to use an external MQTT datasource or Broker.
That's true, the MQTT extension only provides the MQTT client, and my users used 3rd party Broker.  It's like when we are posting data to TWX for tests, we would use Kepware, also an independent tool from TWX server.
Could you elaborate as to how you used kepware ?
Also, is there any other way to use ThingWorx as an mqtt broker. Any way possible?
zyuan15-Regular MemberAnswer
