Create Username and password for organization
I want to create an login page for my organization and login using username and password.
I have followed the instructions at http://support.ptc.com/cs/help/thingworx_hc/thingworx_6.5_hc/index.jspx?id=FormLoginPagesforOrganizations&action=show
I have been able to create a Login page but what username and password should I use for successful login?
The link above descibed as
#8.Type your Name and Password.
But I am not sure which username and password to enter.
Please Help.
shreekant
shreekantAnswer
Thanks for your reply. I have been able to login with the guidelines https://developer.thingworx.com/en/resources/guides/data-model-security-control
but still I am facing a problem that the mashup is not able to load though it is present there.
I am getting error as Could not load "MyMashup". Reason: 404 - Entity Not Found : [MyMashup]
I have assigned a mashup to the user which I am using for login.
Hi Shreekant,
You need to use login details of the User, available under the organization,for which you created this Form Login page.
Drop screenshot for detailed help.
@shreekant
Thank you for your post on community. Have you created any user under organization in ThingWorx? If yes then you can login with that.
While creating user you should have assign a password to that. Please check it or change it if do not remember.
For custom pages you can try below article:
https://www.ptc.com/en/support/article?n=CS236678
Do let me know in case of any question.
shreekant1-VisitorAuthorAnswer
Shreekant,
You need to provide visibility permissions to that particular Mashup(home).
Once you open Mashup,on Left pane side--> Visibility (under permissions).
