Create XML
is there an easy way to create valid xml code? Or is the only way to work with string operations?
Thingworx uses the E4X to work with XML: Processing XML with E4X - Archive of obsolete content | MDN
So creating an near empty Object like in Chapter: Creating an XML object
var languages = new XML('<languages type="dynamic"><lang>JavaScript</lang><lang>Python</lang></languages>');
or
var languages = <languages type="dynamic">
   <lang>Python</lang>
</languages>;
And then work with the xml object like you would parse it, but set values to the nodes and attributes
or
   <lang>Python</lang>
</languages>;
