Created Model in API doesn't show up in Analytics Builder
Hello all,
I have created a Time Series prediction model in the API. Than I added the JobTags but the model still does not appear in the Analytics Builder.
Does anayone has an idea how I can fix this problem?
ThingWorx Version: ThingWorx 9.0.2
Thank you already in advance.
Kind regards
David
Hi David
Is it possible for you to share the code you use to create the job and add the tags ?
Also note that even if the model appears in Builder, because it is an API job as opposed to a Builder one, it will not have all the functionality seen in Builder. It will mainly only be a way to list in the model table, the validation details of the model will not be available.
Christophe
