Creating a steam programatically
I have been creating new stream with the following service:
// Example: For Node1 the stream will be named Node1Stream
var streamName = nodeName + "Stream";
var newStreamParams = {
    description: undefined,
    thingTemplateName: "NodeStreamTemplate",
    tags: undefined
var dataShapeParams = {
    name: "NodeDataShape" /* DATASHAPENAME */
try{
    // Create new Stream
    Resources["EntityServices"].CreateThing(newStreamParams);
    // Set datashape
    Things[streamName].SetDataShape(dataShapeParams);
    Things[streamName].EnableThing();
    Things[streamName].RestartThing();
catch(e){
    logger.error("Unable to create Thing:" + streamName);
    var params = {
    Resources["EntityServices"].DeleteThing(params);
This seems to work fine, but it gives an error to the log:
2016-01-28 10:14:36
ERROR
Invalid DataShape [] assigned to stream Node1Stream
<my email>
c.t.s.StreamThing
Is there a better way to do this and avoid the error message? Is it possible to define the data shape directly when the new stream thing is created?
Instead of creating a new stream from scratch, I have an existing prototype stream that I clone.
var streamName    = nodeName+"Stream";
try
  Resources.EntityServices.CloneThing({
    sourceThingName : "_Prototype_NodeDataStream",
  var thing = Things[streamName];
  thing.EnableThing();
  thing.RestartThing();
catch (error)
  logger.error("Unabled to create stream: "+streamName);
try
catch (error)
That solved it! Thanks!
