Creating chart in Thingworx
I am developing Thingworx web application that reads different sensor data being published over an MQTT protocol. I subscribe to a topic and getting the values displayed on a Gauge widget.
Now, I want it to form a chart based on the sensor data being received. I watched the "how to create and configure chart widget" video given in the developer community where they are getting an option of GetStreamEnterieswithData in the Add data section. I am not getting that option. I don't know where I am going wrong.
I am getting the data in the Gauge but I also want it on the chart. Please help me with proper steps on how to configure chart widget with MQTT??
Thank you!
22-Sapphire I
You need to either
1. use the MQTT topic updated to parse out data and write that to a Stream
2. use the MQTT topic updated to parse out data and write that to actual properties and log those
then you can use the Stream or ValueStream to populate your chart with historical data.
jdave11-VisitorAuthor
I did exactly what you told in the second comment. Data from MQTT server being parsed in the properties and logging it. Then using value stream to populate the chart. I am getting data on the label but not on the chart. If I set the value manually from the properties, it gets plot on the chart but not from the data received over MQTT. I am getting the same data on the label without any issues.
Here are the screenshots of my project. Please let me know where I am going wrong. Thank you
Screenshot (325).pngScreenshot (330).pngScreenshot (327).pngScreenshot (331).pngScreenshot (328).pngScreenshot (329).png
22-Sapphire I
Did you set the X and Y axis for the Chart?
hard to tell for sure, but as far as I can tell everything looks to be done correctly.
Hello, did you find final solution how to correctly store data into valuestream for next chart creation? I have same problem manualy are stored data in valuestream but data from mqtt broker does not store, they only set property value and you can view it. What may cause this behaviour? Many thanks for any response...
