Creating default parameter of mashup
I wanted to set the first state of radio button as default selected state without clicking it.
I found a response in community saying to set the default parameter of mashup as selected value to radio button but I do not find any space in properties of mashup to set the default parameter. How to create the default parameter of mashup?
Please provide some guidelines.
The parameter of Mashup is just an interface and it cannot store default value,
You can use Session variable instead, in UserManagementSubsystem, add a new Thingshape to User Session Shape in the Configuration. You can set default value in there.
Support
Hi @svisveswaraiya_285988
If the response provided by @zyuan1 answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
