May 1, 2017 4:49 PM UTC
CSDK Connnection issue
I'm getting the following errors connecting a raspberry pi with the CSDK, does anyone know what can be causing this?
[FORCE] 2017-05-01 12:27:53,686: Starting up
[DEBUG] 2017-05-01 12:27:53,692: twWs_Create: Initializing Websocket Client for :8224//Thingworx/WS
[DEBUG] 2017-05-01 12:27:53,692: twTlsClient_Create: Initializing TLS Client
[DEBUG] 2017-05-01 12:27:53,693: twTlsClient_Close: Disconnecting from server
[ERROR] 2017-05-01 12:27:53,693: twWs_Create: Error creating BSD socket to be used for the websocket
[ERROR] 2017-05-01 12:27:53,693: twApi_Initialize: Error creating websocket structure, retrying
  [DEBUG] 2017-05-01 12:27:58,693: twWs_Create: Initializing Websocket Client for
posipovaAnswer
20-Turquoise
May 2, 2017 6:09 PM UTC
What are your platform and SDK versions?
Also please check for 1. firewall 2. DNS on the pi. Might need to manually add an entry
20-Turquoise
May 1, 2017 6:17 PM UTC
Can we see your configuration? this line points to a possible issue :
​Typically it should be <hostname:port>//Thingworx/WS
for example localhost:443//Thingworx/WS
May 1, 2017 6:53 PM UTC
Omitted part of the information with [ ]
tw_host=[I have url in here].thingworx.io
tw_port=8443
AppKey=[I have my app key in here]
ScanRate=500
tw_name=JetEngine01
FAE_BoardEnable=false
PinConfig=pinConfig_rPi2.json
Debug=true
IPLocation=true
20-Turquoise
May 1, 2017 7:07 PM UTC
Do you have SSL configured properly? https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS193947
