Dec 24, 2024 6:01 AM UTC
CSS styling for Menu Widget
Hi Team,
I need help in CSS styling in Menu widget - In my requirement I have list of menu items should be listed from dynamic service, in that "title" should be like below (Font-weight : Semi-Bold; upto dot and Font-weight : normal; after dot)
  • Menu1.Sample Page
  • Menu2.Sample Page
  • Menu3.Sample Page
I tried with below CSS it helped with me updating all text as semi bold.
.menuList .widget-menu .menu-item-name span {
 font-weight: 600 !important;
TWX : 9.6.2
Thanks & Regards,
Arun C
PEHOWEAnswer
Mar 18, 2025 3:42 PM UTC
Hello @Arun_C ,
The format you are requesting is not a supported configuration. I would recommend that you add your desired format as a enhancement request.  Make a posts in the "ThingWorx Ideas" group.
pehowe
Dec 24, 2024 11:27 AM UTC
Hi @Arun_C  Can you try the steps of the below post, and let us know your output?
https://community.ptc.com/t5/ThingWorx-Developers/applying-css-to-menu/m-p/729042#M52103
Arun_C16-PearlAuthor
Dec 29, 2024 6:49 AM UTC
Hi @Surya_Tiwari ,
CSS which I'm looking out is different. The above given CSS has different use case but the same is working for me in hover. Help me with my use case Menu "title" should be display like below (Font-weight : Semi-Bold; upto dot and Font-weight : normal; after dot)
  • Menu1.Sample Page
  • Menu2.Sample Page
  • Menu3.Sample Page
Thanks & Regards,
Arun C
Jan 6, 2025 7:37 PM UTC
Hello @Arun_C ,
I am not familiar with the style you are  trying to accomplish.  The documentation has 2 style described, cascading and Nested according.
If I understand your goal is to have the main menu item repeated on each line with the sub menu item on the end with a dot as a separator.
The other customization is to have the main menu item BOLD.
I will see if the experts on using CSS can offer any suggestion. Please let me know I have the proper goal.
Pehowe
PEHOWE17-PeridotAnswer
Hello @Arun_C ,
pehowe
Mar 28, 2025 1:32 PM UTC
Hi @PEHOWE ,
 Thank you for the confirmation. I will post it in 'ThingWorx Ideas' group.
Arun C
