Feb 12, 2019 5:38 AM UTC
CSV Parser
Can anyone suggest me, when there are multiple files in the repository(for ex: XYZ_01FEB,XYZ_02FEB something like this) and i'm using the CSV Parser Read File functionality,how can i make sure my service is reading each file. For example every 5 min the new file will get added to the repository.So how can i read each file here when the naming convention changes(timestamp gets appended to the file eachtime a new file gets placed).
Feb 12, 2019 8:00 AM UTC
You should leverage FileRepository methods in order to list files and act accordingly:
  1. ListFiles({ path: "" }
  2. Iterate over previous list files
  3. For instance once a file it's processed, remove or move to another folder with:
    1. DeleteFile({ path: "" })
    2. MoveFile({ sourcePath: "", overwrite: true/false, targetPath: "" })
Feb 12, 2019 8:48 PM UTC
Hi !
I did not get this.
Could you please explain me this still more.May be with some example code. Since the file names are different i'm not able to do this.
