Curl Command inside service
Hi All,
Can i use a curl command inside js service?
Also I have an URL as   ~ http://win-hkdrt6do2m5:8080/historian-rest-api/v1/tags?nameMask=* ~
Can I get the json from there by using the content load functions?
Thanks!
Anselmo.
If it's not a complex petition, you can just use Content Load Snippets.
Actually, I need to pass a token as parameter for authorization...is that too complex?
Shouldn't
