Current session info not cleared after browser restart
As I understand docu for Session parameters, it should be cleared every time I switch off browser (and in few more cases). But it looks, like it's kept forever.
I have application, where you choose area, and data for this area are presented. Then you can choose any location from this area, and application generates more detailed information about this location only.
As this process takes a lot of time, I've decided to store them as session parameters. If they are needed again (eg. to generate chart), I take data from session parameters, do not re-generate them again. And at this point, it works.
But I was using this application yesterday. Closed all browser windows. Switched off computer. 19 hours later or more, I log into TWX - datas are still there. Logout, close browser, open different browser (previously it was edge, so I used Chrome), log into TWX - datas are still there.
Have checked timeout, keeps default value (30 mins).
Is that normal behaviour? Does it depend on some settings (if so - which one)? Can I somehow push to clear this session info from my service(so I could start such service everytime when I open my mashup)? What if start this app at different PC with my user and will not reach moment when data are generated - it will read previous data? Or if use this same PC but log as different user?
Function used to store info:
Resources["CurrentSessionInfo"].SetGlobalSessionInfoTableValue({name : "myname", value : resultInfotable});
Function used to read info:
result = Resources["CurrentSessionInfo"].GetGlobalSessionValues().myname;
You're perfectly rigth, it is supposed to be what you described. I did exactly like you (just instead having an infotable, I set a String for easyness) and it works fine to me: After restarting browser it disappeared.
Then, I tried to set this on my Global Session Shape (see picture below), and now I have exactly the same behaviour than you have !! It seems that when we actvate this, it works a bit more like cookie (not sure if it is stored on server or client side)
So maybe, try to check on your side if you have "Persist" activated on your session property.
Guillaume
Guillaume
