Cursor customization
Is it possible to change the cursor(arrow mark) to hand image?
TonyZhangAnswer
Support
@AP_9587236,
Collection widgets allow you display multiple base mashups.
Assign a name to CustomClass property to the base mashup.
Write below custom css code in base mashup.
.ReplaceMeWithActualCustomClassName {
      cursor: grab;
22-Sapphire I
Cursor changes are usually associated with Hover and Click, you should be able to do that in CSS
We have 700 entities. In which mashup (or) where i have to use css code for hover and click functionality of user?? And What is the css code for that??
Support
You can use below css in mashups or masters to change the cursor to hand image when mouse not hovering on any widgets.
body {
    cursor: grab;
To change the mouse over style on widgets, you'll need to use custom css to target each element and change the cursor style which might not be feasible for some elements.
22-Sapphire I
I unfortunately do not know CSS, ThingWorx supports a 'master' css theme so that's probably where I would put it.
