Jan 11, 2022 7:03 PM UTC
Custom extension using Eclipse
I am following this guide https://developer.thingworx.com/en/resources/guides/eclipse-plugin-thingworx-extension-development-tutorial/chapter-11-build-extension
I am having no sintax errors, as I copied the example code to be sure. But I can't build it after following every step. It gives me this only error
https://justpaste.it/4hudv
(I uploaded the error to justpaste.it because it is too long for this post)
I am on Windows 10
Eclipse Version: 2021-12 (4.22.0)
Build id: 20211202-1639
Jan 19, 2022 5:31 PM UTC
I used Ant instead of Gradle and it worked
Jan 11, 2022 8:07 PM UTC
1. Send your error log to technical support: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
2. Try the solution described here: https://giters.com/EddyVerbruggen/nativescript-plugin-firebase/issues/1850
MD_101467901-VisitorAuthorAnswer
