18-Opal
Custom widget "Hello, World!" Issue
hi, i'm practice custom widget
TW.IDE.Widgets.helloWorld = function () {
  this.widgetIconUrl = function() {
      return  "../Common/extensions/HelloWorld_ExtensionPackage/ui/helloWorld/helloWorld.ide.png";
  this.widgetProperties = function () {
    return {
      "name": "Hello, World!",
      "description": "An example widget.",
      "category": ['Common'],
      "properties": {
      "Salutation": {
          "baseType": "STRING",
          "defaultValue": "Hello, World!",
          "isBindingTarget": true
        "TextSize":{
        "baseType":"NUMBER",
        "defaultValue":22,
        "isBindingTarget":true
  this.renderHtml = function () {
    return "<div class=\"widget-content widget-helloWorld\">" +
             "<span style=font-size: "+ this.getProperty("TextSize") +"px;>" + this.getProperty("Salutation") + "</span>" +
           "</div>";
  this.afterSetProperty = function (name, value) {
    return true;
  this.widgetEvents = function () {
      return {
          'Updated': {}
Hello, World We tried to construct a user widget that adjusts the font size by moving the slider using the example.(29 line)
However, the font size does not change.
The content inside is also unchanged.
How do I show the values that are bound in the widget?
seonho Cha​: Please confirm if this issue is still open and need suggestions.
-Durgesh
CHASEONHO18-OpalAuthor
18-Opal
Hi, Durgesh Patel
I am trying to create reactive text.
We're still trying it now.
thank
Hello, could you make it works in IDE (Composer) ?
18-Opal
origin hello word extension working
modified hello word extension working but, text size can't change
.salutation {
  font-family: Impact, monospace;
  font-size: text-size // <- it defined properties in ide.js
  text-transform: uppercase;
I am weak in both span, style, and css.
After creating the responsive text, I want to create a thermometer widget.
I have a thermometer picture in the background and I plan to make it by adding Thingworx's vertical slider, but it's not possible at this time (because I do not know everything about span, style, css, value binding,
Is there any material that will help us to get direction in this situation?
thank
