Custom widget selection issue
I have created a custom widget. For the 1st time, the selection of widget works fine when added in mash-up. All the widget properties are loaded and I can assign relevant properties with no issue.
When I add multiple instances of my custom widget into the mash-up, I can only select and see last added widget properties window. I cannot select and see the widget properties window of the previous widgets.
Also after closing and re-opening of mash-up, I cannot see properties window of any selected widget.
I am getting following error when I select custom widget.
Error in TW.IDE.updateWidgetPropertiesWindow TypeError: s.replace is not a function
Any help will be deeply appreciated.
