May 5, 2025 6:56 AM UTC
Data change event for windchill database
We are using thingworx navigate to fetch data from windchill. We used scheduler to trigger services on daily basis.
But now customer wanted to execute service whenever there is a change of value in workflow state. Any idea on how to achieve this use case ?
May 6, 2025 1:56 PM UTC
You should try then to initiate the process from Windchill (through a listener ?) and then call the service in ThingWorx side.
I am not considering any performance topic !
Best Regards,
Best Regards,
May 6, 2025 2:16 PM UTC
That sounds like an event subscription. You can create these with webhooks between Thingworx and Windchill
Br,
Roger
