Data Export unable to export grid data in Tabular Form
I have used Data export widget to export Grid data in Excel/CSV file in Tabular Form. but its exporting in Comma separated ...i binds export button to property of type infotable. using ThingWorx 8.5.10-b597
Note- I had used Data export earlier in TWX 8.5.2 and there it was able to see tabular data in CSV.
Hi @Ciprian-Traian ,
This got Resolved and it was due to binding Property of type Infotable to Export button . i tried binding service which returns Infotable to Export button so its working fine.
FYI-i had used property of type infotable to Grid as well but i was able to see data in Grid.
HI @VS_9760165 ,
It may be an issue in ThingWorx 8.5.10.  you can use 8.5.11, 9.0.4, 9.1.0 . Do you happen to have this issue on Android or iOS ?
Hope it helps,
VS_97601651-VisitorAuthorAnswer
