Jan 4, 2018 1:03 PM UTC
Data filter for a list of numbers.
I have a list that displays n no. of vehicle numbers.
I wanted to add a data filter which displays this list.
I have a service to display the list (table from sql).
How to implement a query property for this case?
I dont understand from where to call implementingthingwithdata.
Please provide some solutions on how to proceed this case.
I wanted to display this set of serial numbers using data filter.
V.Shalini.
22-Sapphire I
Jan 4, 2018 1:40 PM UTC
If this is directly coming from an SQL database, you can just write an SQL Query for it.
Usually what I do with more complex queries I use one regular Thingworx service to create the SQL Query as a string and then I execute it with a Thingworx SQL Query Service using << >> for String substitution.
Please remember that when using string substitution you must apply proper security to protect against sql injection
If it is a fixed service then you can just wrap this service with another Thingworx Service that applies the Query to the infotable
Jan 8, 2018 12:52 PM UTC
Hi Pai chung,
Is it possible to give query as a property?
I mean how to bind the data to generic query property history?
Please provide some guidance.
V.Shalini.
