Data is send back to thingworx
I am creating an extension for a widget in that 'StartDate' is entered through an input field. It is also input to a parameter in a service. I have bound 'StartDate' to that input parameter in the mashup builder. The parameter is a property of a thing. But I don't know the code after this given below to send 'StartDate' to the thing.
What is the code to be written in afterRender and updateProperty functions?
'StartDate' : {
'baseType' : 'DATETIME',
'defaultValue' : '',
'isBindingSource' : true
Hello alinak,
It has been some time since your initial post and I wanted to see if you were able to find a resolution which would help others here on the ThingWorx Developers Community. If so please share when possible.
Additionally if you have not been able to find a resolution to this I would like to recommend having a look at the Example of Creating a Customized ThingWorx Widget Help Center. There is some sample code which I believes discusses how to make the StartDate parameter in your example bindable to a Thing's property. I'd also recommend checking out the Create a Mashup Widget Extension Guide on the ThingWorx Developer Portal.
-Tyler
