pshashipreetham
Data Logger
When Ever Kepware is getting the data from the DB/SQL Server, the tags are getting created by the name "table7_channel1_device1_property_name", I don't want table7 in the tag names. I can't rename the 470 tags by manually modifying each and every tag.
What is the best solution?
Shashi Preetham.
pshashipreetham
Hi @PaiChung ,
I have renamed all tags, manually.
Shashi
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
22-Sapphire I
For what reason do you need to have that removed from the tags?
Since these usually are bound to something else, the tag names are abstracted away for the end user.
pshashipreetham
Hi @PaiChung,
for Business logic I need to remove this table6 in the tag names, can it be done?
if it can be done, then how?
Shashi
22-Sapphire I
I'm not too familiar with how your tags are coming in and how you want to use them.
If you are just pulling a table with tags in it, you can use a regex or something similar perhaps to remove them.
pshashipreetham
pshashipreetham19-TanzaniteAuthorAnswer
Hi @PaiChung ,
Shashi
Support
Hi @pshashipreetham
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
