pshashipreetham
Data logger without Thingworx
I have connected an SQL Server to the Kepware Data Logger, Whatever the data is coming from the tags should go to the DB instead of the Thingworx.
I wanna Remove the Thingworx IP from the Project --> Properties  --> Thingworx ---> Remove Thingworx Interface and want to send the data to a SQL SERVER using Data Logger.
How can I do it?
@c_lowy
pshashipreetham
By Disabling the Thingworx interface from the Project---> Properties ---> Thingworx---> Server Interface, change it to No.
The above setting worked for me.
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
@pshashipreetham : Have you checked the below links which describe setting up dataloggers?
Video guide: https://www.youtube.com/watch?v=vc10DzmUTaA
Documentation: https://www.kepware.com/getattachment/ec757aee-9618-4190-86e0-4524cd1a55f7/datalogger-easy-guide.pdf
@pshashipreetham : Can you please try setting dataloggers as per below links?
Video guide: https://ind01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Dvc10DzmUTaA&data=04%7C01%7Cct.senthilkumar%40ltts.com%7C365e71f867494ed395c808d8d3517319%7C311b33788e8a4b5ea33fe80a3d8ba60a%7C0%7C0%7C637491694488487324%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C2000&sdata=Lw%2FIrH%2Fzbnwz113t5M6W%2FoH8HKQ5Aib%2BgFDGQklgP4A%3D&reserved=0
Documentation: https://ind01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.kepware.com%2Fgetattachment%2Fec757aee-9618-4190-86e0-4524cd1a55f7%2Fdatalogger-easy-guide.pdf&data=04%7C01%7Cct.senthilkumar%40ltts.com%7C365e71f867494ed395c808d8d3517319%7C311b33788e8a4b5ea33fe80a3d8ba60a%7C0%7C0%7C637491694488487324%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C2000&sdata=39NIMt4w7QbAFKcyraB9LD0hWq2K0syj%2BGgqrTuCZmI%3D&reserved=0
pshashipreetham
pshashipreetham19-TanzaniteAuthorAnswer
