Aug 5, 2019 7:12 PM UTC
Data store integrity violation error occurred when create a thing
What is going on? Other things are created successfully, except THING_120573
JavaException: java.lang.Exception: Unable to create thing: THING_120573 : [1,002] Data store integrity violation error: [Error occurred while accessing the model provider.]
Any help would be greatly appreciated.
Remarks, SpotlightSearch returns nothing, GetGhostEntities returns an empty array, however thing_model table contains a row with that name.
My Bests,
Hung Tran
cmorfinAnswer
Aug 6, 2019 10:38 AM UTC
Hi @htran-21
Thank you for the details.
It appears then that you isolated why you are getting the persistence violation error.
There is trace of that Thing inside the database and so a new one with same name cannot be created.
It appears that they has been some kind of corruption here.
I would advise to open a case to Technical Support to ensure this is cleared in a safe way.
Kind regards
Christophe
cmorfin19-TanzaniteAnswer
Hi @htran-21
Kind regards
Christophe
Ascherer17
Jun 10, 2026 8:33 PM UTC
I’ve had this issue as well although today my issue was with a Thing Shape.  Usually restarting the platform seems to clear things up, but otherwise running “DeleteGhostEntities” in PlatformSubsystem and deleting the relevant row in the “<collection>_model” table (thing_model in your example) often helps.  It doesn’t hurt to back up the table first, especially if you’re dealing with a production system.
Jun 15, 2026 11:20 AM UTC
you have a zombie entity :) Restarting TWX will show you the thing in Composer.
  • Ghost Entity: The Entities exist in ThingWorx memory but not in the database
    • happens at exception in services which use Create<Entity>
  • Zombie Entity: The Entities are deleted from ThingWorx memory but still exist in the database
    • happens at exception in services which use Delete<Entity>
check article https://www.ptc.com/en/support/article/CS336004?&as=1 regarding Zombie Entities
edit: huh, this was an old topic :P but guess interesting anyway with the new ZombieEntity services :)
Ascherer17
Jun 15, 2026 6:44 PM UTC
Yes, I just learned about zombie entities and the new services in Thingworx 10.1.1 per https://support.ptc.com/help/thingworx/platform/r10.1/en/index.html#page/ThingWorx/Help/Release_Notes/Whats_New_in_ThingWorx_Platform_10_1_1_0.html.
In my instance, I was dealing with Thingworx 10.1.0 rather than 10.1.1.  The ‘resolve’ service might have resolved my problem.
