Data table creation through service scripting
How can i create data table(s) with its data shape through service scripting?
mnarangAnswer
The DataShape which you are passing in the above shared code can also be created through script having primary key
var result1 = { dataShape: { fieldDefinitions : {abc: {name: "abc", aspects: {isPrimaryKey: true}, description: "", baseType: "STRING", ordinal: 1}} }, rows: [] };
var params = {
name: "DSwithPK" /* STRING */,
description: undefined /* STRING */,
fields: result1 /* INFOTABLE */,
tags: undefined /* TAGS */
// no return
Resources["EntityServices"].CreateDataShape(params);
Hope it helps
Thanks ,
Mukul Narang
I have done in this way :
var params = {
name: "MyTestTable1" /* STRING */,
thingTemplateName: "DataTable" /* THINGTEMPLATENAME */,
// no return
Resources["EntityServices"].CreateThing(params);
Things["MyTestTable1"].SetDataShape({
name: "DataShapeWithBoolean" /* DATASHAPENAME */
Things["MyTestTable1"].EnableThing();
Things["MyTestTable1"].RestartThing();
Hope it helps .
Thanks ,
Mukul Narang
muzzammil1-VisitorAuthor
how to set the data shape field as the primary key through scripting?
mnarang5-Regular MemberAnswer
var params = {
// no return
Hope it helps
Thanks ,
Mukul Narang
