Datachange event in the subscription doesnt work when the value is zero in the value stream.
Hello Team,
I have a subscription for a datachange of the property, and whenever there is a data change i am performing certain function and when the value is zero i have to perform certain function.
The data is getting updated by the remote thing and i have a value stream assigned to the thing.
I dont have an issue when the data changes, but when the data for the property is flowing 0 always. the data change event is not getting triggered and i am not able to perform the required action when the value is 0.
Can someone help me and let me know how can i write an event for which every time the data comes to the value stream weather it is changed or not, i have to rise an event and use the same event for subscription.
Sunay
22-Sapphire I
So the event fires based on the DataChange Setting
Value - Whenever the value changes
Always - Whenever the value is written (regardless if it is the same value)
Never - Never
On - Goes to True
Off - Goes to False
sbt15-MoonstoneAuthor
Hello PaiChung,
I have set the property datachange setting to "always" because of which i am able to log data to the value stream even though it is same.
But my problem lies in the subscription, where i have the option to set the event as Datachange for a property. But i don't have the option as always. Here if the data change happens, the subscription functionality is getting executed. If the value streaming is same then the subscription is not getting executed.
Sunay
Hello PaiChung,
Do you have any thoughts on the this??? what could be the reason and how can we achieve it.
Sunay
