Jan 8, 2019 7:55 AM UTC
datashape changing dynamic
Whenever a datashape is created from a sql query it becomes static. If I make any changes in the query like adding a new column or removing I have to again create a new datashape. But is it possible that the datashape becomes dynamic and adjusts according to the query whenever it is changed?
Shalini V.
Jan 8, 2019 8:54 AM UTC
The output of a service as defined can only have one DataShape (only System Services can have "Dynamic DataShapes" to be shown on Mashups - for instance QueryImplementingThings or GetProperties services), but you can always output any amount of columns (dynamic) out of a services ignoring the defined DataShape.
Jan 8, 2019 9:20 AM UTC
Hi @CarlesColl,
Thanks for your quick response.
Do you mean I can output any number of columns and create datashape from the respective output?
Jan 8, 2019 9:21 AM UTC
You can output any number of columns yes, you don't need to create a specific DataShape if it's dynamic.
