mnarangAnswer
I beleive you are trying to import Data from a Data Table for which the entity structure does not exist in ThingWorx. If you want to import Data for DT, you should first import that DT as an entity in ThingWorx. Export the Data Table entity from another ThingWorx and import and then try to import Data for that Data Table.
mnarang5-Regular MemberAnswer
