Delete DataTable entry by timestamp
How might I go about deleting all items in a datatable by timestamp? Say over a year old? I am not seeing timestamp as a parameter of the DeleteDataTableEntriesWithQuery snippet.
18-Opal
Well, just create a ValueStream object, assign it to your thing (or thing template), make your totaldailysheetcount logged and see how it works -- it's really that simple, just execute GetPropertyHistory() on that thing again to see changes history. Check out Help on Value Streams -- it has all technical details.
Support
Hi @Chao123.
Which version of ThingWorx are you running?
--Sharon
Chao1231-VisitorAuthor
I believe it is 8.3.10-b1010
You can use a query ( inside the service) which will delete all data previous to the timestamp defined in value :
"filters": {
"type": "LT",
"fieldName": "timestamp",
"value": "2020-01-30"
Thank you for your suggestion. I am not doing this correctly obviously.
var query = {
"filters":{
"type": "LT",
"values": "2020-01-30"
var result = me.DeleteDataTableEntriesWithQuery(query);
This will still delete all of my entries even if they are not LT the value. Not sure what I am doing wrong.
DeleteDataTableEntriesWithQuery is expecting a numeric value that represents milliseconds since epoch:
var query = {
 "filters": {
 "type": "LT",
 "value": new Date("2020-01-30")
