Delete value from infotable based on input in textfield
hii,
I have input textfield and button in my mashup. If we input the value and press the button the row containing the value should be deleted from the info table. how can I do this?
Thanks and Regards
SOLVED
Hi PS_10076728,
If you already solved the issue from your post, for the benefit of other Community Members who may have the same question, it would be great if you could provide the solution in the same post and then designate it as the Accepted Solution.
Thanks for using the PTC Community!
Simona
