Deploying to a lot of EMS running on Rasbperry pi
after reading the RPi Temperature & Humidity Tutorial on the thingworx academic website, I found out that the deploying process is rather manual.
http://www.thingworx.com/~/media/Files/PDFs/Academics/1RPSetupyourRaspberryPiBoard.ashx?la=en
I thought that the deploying process can be done directly from within thingworx. Let's say I configure a remote thing called myRPi1 that is bound to the once manually installed EMS on the RPi. Is it possible to update the parameters and values directly from the thingworx thing myRPi1? Or do I need to updated the java files, compile and deploy the EMS after every change I want to make on the EMS side?
Another point is: how can I make the EMS run as a service on the PI, so that if the Pi reboots, it will start again automatically?
thanks
