descriptive analytics tutorial
I'm trying to follow this tutorial
https://community.ptc.com/t5/IoT-Tips/Perform-Statistical-Calculations-with-Descriptive-Analytics-Part/ta-p/834663
I already did until I created the service to put the numbers into the timed values table. but my timed_values not updating. There was no data there.
I also dont understand how below code could put the numbers I set in numbers into the timed_values table since the propertyname is "numbers" not me.numbers
 me.timed_values = me.QueryTimedValuesForProperty({
 propertyName: "numbers",
 maxItems: 10,
 startTime: me.start_time,
 endTime: me.end_time
cmorfinAnswer
Hi @A_10333884
Here are a few points to check:
- In Thing scts_thing > General Information, make sure you have a value stream set
- In Properties and Alerts, make sure your property is named numbers of type NUMBER and has the attribute Logged selected
- For start_time and end_time, do not use the value from the screenshot, you need to set some values that include the time when you set the numbers property.. So if you did that yesterday , set start_time to the beginning of the week and end_time to tomorrow.
cmorfin19-TanzaniteAnswer
Hi @A_10333884
