Difference between mashup template and master template
What is the difference between Mashup templates and master templates in ThingWorx 9.0?
And without the layout widget in ThingWorx 9.0, it is very difficult to do the spacing between each container. Is there a method to key in the spacing of the container as per our wish?
Thanks & Regards,
Shalini V.
Support
Hi @svisveswaraiya_285988
Please refer to this page from the ThingWorx Help Center for answering your first question.
The layout tab in the mashup would be the first place to start in regard to sizing and positioning of your layout.  If you're unable to solve your needs there, you can add containers between other containers as spacers--as small as 1 pixel.
If you still have questions after reviewing the previous information, please provide an example of what you are trying to do, so we can take a look at it.
--Sharon
