9-Granite
Difference between Thingworx Dev license & Production instance license
Hello all,
Somebody kindly clarify the difference between Thingworx v9.1 dev & prdn instance license.
what will happen if we use dev license for production server instance.
Please clarify clearly!!!
AshrithaAnswer
Hi ,
As a license , there is no difference  in Dev and production .
Difference stands only in concept : In dev environment , developer will develop and test the application. But in production , only tested (working) entities/application will be imported. In Dev environment , there can be unwanted entities ,but in production only required entities will be imported for good performance.
ThingWorx installation steps remains same for both dev and production. License will be based on the device Id.
Hello @Sathya
Whatever license you have is always tied to your instance devide ID. And this device ID is unique for every thingworx instance.
so as long as your instance devide ID is different you cannot use same license for different environments.
You can check the device ID in license request file present in Thingworx platform folder and also from the composer via services of licensing subsystem.
Please refer following article to get more info about licensing in Thingworx
Licensing Thingworx
Bhawna
Sathya9-GraniteAuthor
9-Granite
Hello @bchaudhary_448008 ,
thanks for the reply & suggestion,
I got the point on how license will work based on device ID,
but my question is,
"Imagine we have 5 on prem server out of which 1 is production instance & remaining all are  development instances.
assume, i have purchased license from PTC and installed it in one of the dev instance instead of prdn instance, and for prdn instance, using the device id generated one more license key BIN file". please confirm whether it will still holds good or will it act as a development instance & what are all the drawbacks by doing so...
please clarify
thanks,
SB
Ashritha15-MoonstoneAnswer
Hi ,
9-Granite
Hello Ashritha,
thank you very much for confirming, my doubt is cleared
