Directory Service
  • August 28, 2014
  • 8 replies
  • 2724 views
How do I create a new Directory Service?
From the workbook, it states to go to Directory Services and duplicate the default Entity to create your Directory Service. However when I go to Directory Services, I don't think I see a default entity or any entities in the listing. Am I looking in the wrong location or missing a component?
Thanks.
    Hi Victor,
    If you refer to section 06.02 in the Wiki titled, "Directory Services Authentication, " you'll find direction on creating a directory service and an example. You will just copy and paste the example into a text editor such as notepad++ and import it the same way you would would any other entity. This will be the entity you duplicate in composer.
    Thank you,
    Saeed
    victorgan1-VisitorAuthor
    Hi Saeed,
    Thanks, that worked!
    Did you create your users in the Directory service system as well as in ThingWorx?
    Hi Saeed,
    Yes I believe so. The username I created in ThingWorx is the same that exists in Active Directory. Is there anything else I need to configure?
    Which version of ThingWorx are you using?
