6-Contributor
Disabling links in an Advanced Grid Widget
Hi all,
I have an advanced grid with one of it's columns consisting of links. I would like to have each individual link  become disabled upon being clicked a second time, independently from the other links in the advanced grid. With the Link widget I could make it become disabled via a button and some expressions that would alter the Link widgets "disable" property to "true" after a second click, but I don't have this sort of functionality with links that are in an advanced grid. Is there some sort of functionality Thing-Worx has that I'm missing? Or are individual parts of an advanced grid non-interactive?
For the above mentioned use case, collection widget will be the good option.
Cell mashup of collection widget can make use of expressions and validator.
So link can be disabled by using button/expression/validators.
Hope this Helps!!
6-Contributor
I'm just glad to get some more experienced insight on the subject, thank you so much! I'll take a look at this as a viable alternative to the Advanced Grid.
