Display iframe in mashup
I am trying to figure out how to display an external webpage in thingworx. I am trying to use an expression which then outputs html as a string of an iframe, The output of that expression is bound to the data property of the value display.
I have also tried to enter the html into a textinput, But the value display will only display the raw text and not the page which should render.
The value display is set to render the data as html.
Am I doing anything the wrong way, if so please advice me how to do.
Kindly
Oskar Berntorp
TonyZhangAnswer
Support
Hi @oskarberntorp ,
Could you please try adding below in CustomCSS tab of the mashup?
ptcs-value-display::part(overflow-control){
	height:100%;
ptcs-value-display::part(value-container){
	height:100%;
ptcs-value-display::part(item-value-container){
	height:100%;
 width:100%;
ptcs-value-display::part(item-value){
	height:100%;
 width:100%;
 Also, make sure the width='100%' and height='100%' style are applied to your iframe element.
result =
 "<iframe src='https://www.bing.com' width='100%' height='100%' title='Iframe Example'></iframe>";
22-Sapphire I
Isn't there still a webframe widget?
Thank you for answering,
The WebFrame widget exists, but as I need to be able to allow the web page shown to use the webcam. The web frame widget is not flexible enougth as I can't control that I want to be able to use the microphone or web cam. That is why I need to use the iframe element in a value display widget.
But my problem is that the value display shows nothing...
So basically I need to customize the webframe to add an allow attribute (which is the way to allow microphone or camera in an iframe), but as I understand, the web frame widget does not give me that flexibility.
// Oskar Berntorp
Rocko
Have you set the Format dropdown in ValueFormat to "With Formatting" or "With Formatting/Unsanitized"?
I suggest you make that working first, e.g. with a different target site. You will then also have to manage CSRF/CORS as well I guess.
