Display labels on Stack bar chart series
Hi Team,
Can we show different labels on each series of stack bar chart?
If yes, then please share the process of showing labels on bar chart series.
Thanks in advance.
Support
Hi @RK_0705.
Which version of ThingWorx are you running?  Can you provide a mockup of what you are looking to do?
Here's some information from the ThingWorx 9 Help Center.  Notice there is a Youtube video that may be helpful.
--Sharon
RK_07051-VisitorAuthor
@slangley
The ThingWorx version is 9.1.
Actually we want to show the label names on the bar chart series i.e. the names we gets to know over hovering on the generated series of graphs.
@RK_0705
I believe this is working as per design, labels display only after hovering. There are view customization being implemented in ThingWorx 9.2.0 which is yet to release.
We can check for you if this functionality is present or not in newer version.
Mohit
Support
Hi @RK_0705.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
