Display Number/Integer 0 as blank in Infotable
If a column has a value 0, I want to replace the number 0 by an empty string or make it undefined. Is there a way we can do that if the Column is Integer/Number basetype?
zyuan1Answer
The Null is part of String type, but not in Number type.  Only if the source property does not have value assigned, and no default value configured , will the property be null.
If you create a new numeric property and did not log value inside, it will work.
Hi ,
With Integer datatype any value which is undefined will be represented as 0 . So , it's not possible to update 0 with undefined or blank .
zyuan15-Regular MemberAnswer
18-Opal
Hello @rgurram,
As a workaround you can try state formatting, which displays zeros as white text on white background.
Constantine
Support
Hi @rgurram.
If one of the previous responses allowed you to find a solution to your question, please mark the appropriate one as the Accepted Solution for the benefit of others on the community.
--Sharon
