Display PDF in Mashup
I'm trying to display a PDF in the mashup. I know that most people suggest using Webframe and either linking the files from the FIleUploader Widget or create a repository. Is there a way to have a list of PDF names and once its clicked it shows the different PDFs in the Webframe widget.
PaiChungAnswer
22-Sapphire I
The list of PDFs could just be the file listing in a repository.
As you click, you take the file link and bind the 'selected row' of that to the webframe
PaiChung22-Sapphire IAnswer
22-Sapphire I
shaggy8131-VisitorAuthor
I've actually decided to use a tree instead of a list. I put the webframe into a layout itself and it works but i dont like the header (download pdf, rotate pdf, or print pdf). I found a work around this by using a panel and have a label box cover the very top of the webframe, but as you change your screen size the webframe and label doesnt occupy the whole panel anymore. Is there a solution for this?
Thanks!
22-Sapphire I
You can always go with a responsive design approach (i forget if we renamed it in 8.4 .. )
