display Tooltip data in label (Label Chart)
Is there anyway to display data in the label of XAxisField? For example, normally the timestamp can be Jan, Feb , Mar,... but I want Jan \n Data1:10% , Feb \n Data1:15%, Mar \n Data1:20%,... Is it possible?
c_lowyAnswer
Hi @CS_9755001,
The XAxis label format can be defined using widget parameter XAxisFormat. As far as I am aware the only content that can be interpreted by ThingWorx is what is documented in Formatting Date and Time for Widgets as well as normal text that will be rendered as is. This does not include references to data fields.
c_lowy16-PearlAnswer
Hi @CS_9755001,
Thank you very much for your help
I think  the label chart widget sometime looks difficult to estimate value (when print out) that's why I want to display data field to each of data in the chart
Indeed, I get your point.
Please feel free to make suggestions on how the Label Chart widget could be improved through a Product Idea.
