Distribute Collection widget contents in a single row?
Hi all,
I've been recently using the Collection widget to fill in my mashup's contents in a dynamic manner.
So far I've used Table Layout: Flow (Horizontal Distribution). However, this makes it so the Collection is responsive, and it will wrap the mashups within if they do not fit in a single row. How can I make it so it only distributes the nested mashups in a single row of the Collection Widget?
Support
Hi @rnfonseca.
There is an option available in the Properties panel for disabling wrapping.  It is not selected by default.  You might want to check this.
--Sharon
rnfonseca1-VisitorAuthor
Hi @slangley ,
I assume you are mentioning the Collection 'Widget Properties'. I don't have any option to enable/disable row wrapping. I'm using v8.4. Is this a new feature?
I've noted that the disable wrap property is only available in later version of ThingWorx
