Do we have any service to remove or detach Value Stream to Assets?
Hi All,
I know we have a service SetValueStream that can be used to add the ValueStream to an Asset. In the same way, Do we have have any service to remove or detach a Value stream to an Assets?
or we have any other options to remove the values.
Please let me know.
Thanks for your reply.
c_lowyAnswer
Hi @koushal ,
As far as I know there is no out of the box service for that, but you can create a custom JavaScript service and use the SetValueStream service with an empty input like this :
me.SetValueStream({
name: "" /* THINGNAME */
I hope this helps.
c_lowy16-PearlAnswer
Hi @koushal ,
me.SetValueStream({
I hope this helps.
koushal1-VisitorAuthor
HI @c_lowy,
Do we need to enable and restart the Asset Thing after removing the Value Stream?
or Is it fine to remove the ValueStream without restart the Thing?
Hi @koushal ,
I believe the SetValueStream service does not require a Restart after it has been called. Service GetValueStream can be used to validate change of assigned Value Stream.
