Docker Image & Thingworx Offline License
Hello!
Thingworx 7.4+ is running only with License. I used to run my instances with offline license. Now I am trying to work on docker images. The problem is that docker image after stop is changing it's deviceID which is causing error while acquiring license.
Any option to use docker with offline license?
Adam
nsampatAnswer
Adam,
You can download a offline license from the License Management portal located here: https://support.ptc.com/apps/licensePortal/auth/ssl/index
All you need to do is provide your new device ID, and a license file will be generated for you.
Please let me know if this resolves your problem.
Neel
nsampat17-PeridotAnswer
Adam,
Neel
