Documentation of code - ThingWorx best practices
Hi, I work for an FDA regulated company that requires a stringent documentation process of code. Is there a best practice or strategy for using the 'documentation' section of each entity?
Hi Thomas,
I don't think so.
The options you have to documentate code:
  • Entity level Documentation as you said
  • Services
    • Description field at Service Level
    • Each Input parameter has it's own Description section
    • Output has it's own Description section
    • Code
      • You can use standard Javascript comments ( /* */ and // )
  • Properties
    • Have a Description field
  • Subscriptions
    • Doesn't have any Description Section you will have to relay on Inner Javascript comments or enforce to always on the inner code call a Thing's Service which it's documented
  • Events
    • Have a Description Section
Just one last perk, when you save an entity on the composer if you click on the button next to Save you can write a comment on what's modified.
As you can see TW it's well designed to documentate everything, where it fails it's then if you want to generate a "printable" version of everything you had write on previous parts. But you can enter on "Server" view and see everything you documented: "yourServer"/Thingworx/Server
Hi, Thomas.
I'm not sure that we have specific documentation that calls this out. Let me see what advice I can get for you here.
-- Craig A.
Hi Thomas,
I don't think so.
  • Services
    • Code
  • Properties
  • Subscriptions
  • Events
hortemt1-VisitorAuthor
This is helpful, thank you!
