Feb 15, 2018 2:40 AM UTC
Does anyone know how to use Resources["SearchFunctions"].SearchPeople in ThingWorx?
Mar 14, 2018 9:41 AM UTC
var params = {
maxItems: undefined /* NUMBER */,
searchExpression: "El*",
modelTags: undefined /* TAGS */,
query: undefined /* QUERY */,
aspects: undefined /* JSON */,
excludedAspects: undefined /* JSON */,
maxSearchItems: undefined /* NUMBER */
// result: INFOTABLE dataShape: SearchResults
var result = Resources["SearchFunctions"].SearchPeople(params).peopleResults;
Feb 15, 2018 8:21 AM UTC
What does you mean on how it works?
You have a snippet to use it, just on the snippets write SeachPeople and it will pop the SearchPeople snippet if you mouse over you have an explanation of each parameter.
liliu5-Regular MemberAuthor
Feb 20, 2018 1:25 AM UTC
Hi Carles,
I know this function can be copied from snippets. However, I don't know how to set the parameters for this function.
var params = {
searchExpression: undefined /* STRING */,
var result = Resources["SearchFunctions"].SearchPeople(params);
Since I don't know it's searching result, I don't know how to set the parameters.
Could you please give me a sample?
Best Regards,
Olivia
Feb 20, 2018 8:00 AM UTC
But what you are trying to query for?
Emeritus
Apr 6, 2018 4:19 PM UTC
Hi @liliu
Just wanted to follow up to see if Carles's response answered your question.  If so, please indicate Accepted Solution for the rest of the Community's benefit.  If not, please advise on current status.
Thanks!
Leigh
