Aug 19, 2026 2:49 PM UTC
DOTNET SDK and Linux
I would like to target Linux for an application I created using the DOTNET SDK. I see it targets NETSTANDARD2.0 and I did some poking around to look for any windows only calls. Only see some paths that are windows like hardcoded. I also saw this link from 3 years ago which clearly states the SDK is for windows only
ThingWorx Edge SDKs | Community
Also maybe I missed something in the documentation that states this but I am simply wondering if I can use this assembly in an application that targets Linux.
Thanks in advance
smainenteAnswer
Aug 20, 2026 8:49 AM UTC
Although the .NET SDK 5.9.0 is now compatible with .NET 8.0, it is only supported on Windows. The C SDK and Java SDK are portable and can run on Linux.
smainente16-PearlAnswer
Aug 20, 2026 12:04 PM UTC
Thank you very much. This is very helpful. If it is in the documentation for the DOTNET SDK then I missed it. If it is not it would be nice to have exactly what you said included. Regardless - thank you again and have a good day.
Aug 21, 2026 8:10 PM UTC
To ensure access to the most up-to-date compatibility information, we have moved the Compatibility Matrix and Product Interoperability details from the Help Center to Release Advisor.
.NET SDK 5.9.0:  https://release-advisor.ptc.com/releaseMatrix?releaseId=1888
