Sep 19, 2019 11:20 AM UTC
download historical sensor data
Come faccio a scaricare i dati storici del sensore nell'applicazione Creo Product Insight da un server ThingWorx.
Grazie
Sep 24, 2019 2:07 PM UTC
Hello  @titurbina,
I hope the translation of google is so far  ok:
"How do I download historical sensor data into the Creo Product Insight application from a ThingWorx server."
Could you, you please, provide more details about the intention the goal what you want to achieve?
So far, I understand you have a value stream data, right?
Let say it represents a measurement for an  angle of mechanism part for some time range.
Also, in Creo Parametric you have an mechanism which should  use this angle as measurement.
So now I suspect you want to use this data /historical data associated to the measurement of your mechanism in Creo Parametric (in Creo Dimension on a pin join)
When you configure /setup Creo Insight you are prompted  to select a thing having a value stream (let say with angle property) . so, what I believe you can do  - > is to copy your historical data to this value stream. To copy a data to a stream I think the simplest way is to  use custom service  which read you historical data and will write to the value stream.
Unfortunately, I have currently Installation of Thingworx server without  Creo If there is more details required  - in this case  I need to check it more deeper and , of course , to  install the Creo Inside to my current environment.
titurbina1-VisitorAuthor
Sep 25, 2019 6:25 AM UTC
 Other information, as per attached file, thanks
Sep 26, 2019 3:12 PM UTC
Hi
This video shows all the steps to achieve this, so hopefully it can be helpful.
https://community.ptc.com/t5/IoT-Tech-Tips/Configuring-Creo-and-ThingWorx-for-the-Creo-Insight-Extension/m-p/545270
Kind regards
Christophe
