Dropdown widget
Thingworx : 8.5.2
Unable to set border bottom color for each item in the list.Please let me know if it can be done using css
CharlesJiAnswer
Support
Hi @krishnakomal123, have you tried Style Theme? The CustomCSS won't reflect if the property is already defined by the Style Theme.
Create a new Style Theme and find the settings under Styles > Elements > Grids and Lists > Lists and Dropdowns.
Then bind it to the StyleTheme property in the Style Properties tab of the List.
@krishnakomal123 : Have you tried using a custom CSS for this? This should be achievable using that.
yes,but it's not at all reflecting.
Can you help me on this?
