Oct 10, 2025 6:57 AM UTC
Dynamic Overrides for Line Coordinates (x1, y1, x2, y2) Not Applying in SVG
In the current ThingWorx (v10.0.0) SVG implementation, when attempting to dynamically override the coordinates of a element (x1, y1, x2, y2) via data-binding or the override mechanism, the changes are not visually applied to the SVG.
Although the updated values reach the browser (confirmed via the network tab), the rendered SVG does not reflect these changes. Inspecting the DOM shows that the line element’s coordinate attributes remain unchanged. This indicates that the current runtime code does not correctly apply dynamic updates to coordinate attributes for elements, even though style and other override attributes are applied correctly. This needs to be fixed urgently . Please help
Support
Oct 17, 2025 2:07 PM UTC
Hi @dev_1827
Apologies that no responses have been received on this post.  If you or someone within your organization has a support account, I recommend we open a case for further review by one of our subject matter experts.  I'm happy to open the case on your behalf, but you will need to provide the contact information for someone with a PTC Support account (under private messaging).
--Sharon
