Dynamically adding widgets or elements to a mashup using a service
My goal is to give a end user the ability to create a custom report for other end user to use/input data.
First is this possible. if so I was thinking about using a collection widget. Some research has shown I could use the Mashup Builder extension to add widgets to a mashup. But I can find this extension or any information on it.
Hi @RyanInterstates ,
Mashup Builder is not an extension, it's the interface in which you build this UI you're trying to build. When you add a New Mashup and go to the Design tab, that is it.
The Collection widget accepts mashups for the cells it displays, you can also dynamically give them widths and heights from the same dataset. What you put into those mashups is up to you.
BR,
Gabriel
